On switches that support only a single active VRF, ensure a user-defined VRF with a different name does not exist.
Perform this procedure to specify the VRF that Auto-sense uses for the SD-WAN configuration. On models that support a single active VRF, Auto-sense cannot create the dynamic SD-WAN VRF if an IP configuration already exists.
If the running switch configuration includes the dynamic SD-WAN VRF and you complete this procedure, the switch renames the dynamic VRF to your specified name, and converts the configuration to static.
enable
configure terminal
